Realtek Driver
Is RTL 8111C Ethernet supported by MIkrotik OS?
It work fine! on my MT3.20
Just do it
Some of the older cheaper Realtek nics off loaded processing to the host CPU from what I heard. In years past when I used them on my PPPoE server or other high PPS applications I had troubles. Moving to 3com or Intel nics and issues went away. Is the RTL 8111C the same way?
Matt
What kind of trouble do you have?
I’m running fine with four RTL8111C about half year.
They are like Intel or 3Com Nic for me… Ultra Stable
