Realtek PCMCIA cardbus RTL8169 not working
Hello
I try to make work a Realtek gigabit cardbus (PCMCIA) card at an x86 computer
Mikrotik sees the card but a connection can not be made
Similar problems existed at later linux versions but with the Realtek own driver
it worked ok.
I have 2 of these cards and none works.
Mikrotik sees it but no connection established , not connection led
If I use a patched linux everything is OK.
The mikrotik pci recognises it as :
RTL-8169 Gigabit Ethernet (rev: 16)
I tried the 6.32.4 version
