Realtime per IP traffic monitor attix5 monitor problem
Hi
my network: 192.168.1.0
mikrotikrouter 192.168.1.1
host computer 192.168.1.187
i have done everything like on this instructions:
https://www.youtube.com/watch?v=yNaRKUoojyI
https://www.youtube.com/watch?v=gP7GFqzmhj8
My ini file looks like
[Settings]
#Required settings are uncommented
#Defaults are shown
#Capture packets from this network (ignore internal traffic)
#Comma-separated values are accepted. Specify a mask for each network even if they are the same.
Network=192.168.1.0
Mask=255.255.255.0
#Match everything BUT the above (only for special custom situations):
#InverseMatch=0
#Mikrotik Server
Mikrotik=192.168.1.1
MikrotikSSHUser=sn
MikrotikSSHPassword=sn
#This is combined with the Mikrotik IP address to create the accounting URL:
AccountingPath=/accounting/ip.cgi
#Alternative service port to listen on
ServicePort=81
#Convert static DNS names to uppercase
#UppercaseStatic=1
#Trim trailing text from DNS and DHCP names
#DeleteSuffix=.mycompany.com
#Clear values weekly (default) or monthly
ClearSchedule=weekly
#Specify a different service name (for multiple services on one machine)
#ServiceName=Sniffer
#ServiceDisplayName=Sniffer
After service star i get in log file:
2017-06-09 12:49:17 - Info: Service started
2017-06-09 12:49:19 - Error: Cannot get traffic: Connect timed out. (192.168.1.1:80)
2017-06-09 12:49:20 - Error: Cannot get traffic: Connect timed out. (192.168.1.1:80)
2017-06-09 12:49:21 - Error: Cannot get traffic: Connect timed out. (192.168.1.1:80)
2017-06-09 12:49:22 - Error: Cannot get traffic: Connect timed out. (192.168.1.1:80)
Firewall is off and no antivirus.
Hi
seems your “www” service port on mikrotik router is 80 but your serviceport has been set to =81. check “SnifferService.ini” and try again.
Dear all members
do you know where can i donwload Attix5 Traffic Monitor v1.0.3 i don’t know where can i download it
could u please help
