I’m trying to reduce the effects of high latency and grossly exaggerated pings to clients from a 433ah w/60-70 clients spread over 3 radios to some reasonable value and would like consensus on what a reasonable number of connections per client might be. The default is 100 but this results in the aforementioned issue so I reduced it to 30 and tarpit the overflow. Do any see a problem with this setup? It does seem to help in the ping times I now generate.
