reboot device over ssh
I try to reboot device over ssh with
/system reboot
or
/system reboot;
but when i execute this code manually it asks for confirmation. how can I auto input Y so that i dont have to press key manually?
any solution?
Try forum search on system reboot confirmation.
http://forum.mikrotik.com/t/force-reboot/32053/16
Just tested this on 6.40rc6 and it works fine.
I found the soultion.. Thanks
And the solution is?
The scheduler is an option. Did you find something else?
Is too hard follow and read already posted link and solution?
:execute {/system reboot}
