I have one modem which I want to restart when it fails from Mikrotik PC connected to the modem. The only way is to stop the power supply for a second with some kind of power relay. The problem is that I don’t know how to output for example 3.3V sgnal from the Mikrotik PC when ping to the modem fails.
The idea is - when ping fails → input voltage in power relay → the relay stops supplying modem with power → the modem is restarted
Maybe I can use beeper for this purpose or some signal from one of the COM ports
You are not helping me
This is telco modem and I can’t touch it (change, configure and so on)
I have concrete question.
Maybe if I ask you how to do better QoS you will tell me to buy 155 Mbps Internet connection.
What about
[admin@MikroTik] > :beep length=5s frequency=10000
the power relay interupts for 5 seconds and the modem is restarted. I will read more about scripting in Mikrotik (I don’t know nothing about it now) and will test it. Then you will have the results
It works like GSM bombs - I think it will work
Did this awhile back: The speaker output was a square wave referenced to ground. Putting a small capacitor across the output (speaker removed) was good to drive a small reed relay.
