Recall critical logs PLEASE HELP
I am trying to recall a specific critical error on my rb600. i have since lost power to my router. i am not sure of the command to use if i would like to recall all critical errors that have been stored on disk? can someone please help?
Thanks, Paul
/log pri where topics~"critical"
I tried the command with no success, does this mean i have lost my critical logs?
Thanks for the help :slight_smile:
yeah, I was always interested: critical logs are stored somewhere, they’re saved between reboots and are shown on first Terminal opening… where can one find’em after that? =)
If you want to view all critical logs even after several reboots, then set up logging rule to log all crytical logs to file.
but you really see ‘echo’ log on first login via CLI even after reboot. once… =)
