Recomend me
i am using crack version of mikrotik now i want to buy it level 6 version. but before i buy it i need some informatoin.
i want to handl 1000 pppoe clients and 1000 hotspot clients. so recoment me computer for it.. HP Core i7 2nd Genraton is enough for it?
2ndly if i installed it on a hard and it got damaged then can i install it on another hard?
3rd Usermanager can work easily with more then 1000 clients without any isue?
no reply bump
Try the chr instead the x86. You can get the unrestricted trial license for free and you can migrate both the system between the machines and paid licenses between the instances.
Yes I agree. Virtual Box or VMware workstation. ESXi is also a possibility that works well. I used VMware vCenter Converter to migrate a Workstation CHR to ESXi very easily.
