Dear All,
Can you kindly recommend a suitable routerboard that will support a 500Mbps WAN connection with some light firewalling. I was planning on getting the CCR1036-12G-4S but I am concerned re the fan noise as this will be used in a small home.
Dear All,
CCR1009 with passive cooling i.e. https://routerboard.com/CCR1009-7G-1C-PC / https://routerboard.com/CCR1009-7G-1C-1SplusPC ?
Ccr1009 with passive cooling will be enough.
perfect thank you
