Dear sirs,
Can you please recommend me a solution for the following;
Point to Point link from rooftop to rooftop (300meters line of sight)
Important is:
Jitter
Latency
Throughput (we need 100M+, the higher the better)
Our budget is ~800€/link (happy if we can do it cheaper, but quality is more important then price)
BR
Fredrik
If you need more than 100Mbit with POE your only option is RB800 with n-Wireless and a good dual-pol antenna.
This is the only board to support 1Gbit Interfaces with ieee802.11af POE.
Your costs might be a bit higher than 800€, but believe me, its worth.
If 100Mbit are enough for you, RB433AH is an option.
RB411AH + R52Hn + dual pol antenna (like AirMax 17dBi) x2 on each side. Both RB411AH connected to RB450G on each side running OSPF.
That’s about $750 per link with full redundancy and up to 300Mbps TCP throughput (150Mbps one way). If your network packets are smaller than 1000bytes -on average- than you’ll need something more powerful than RB450G.
