klaparp
1
Hi.
Please suggest to me what hardware i should use, preferrably something you have tested working.
I need:
2-5 ethernet ports
2.4GHz wifi (output power not important)
internal 4G / LTE modem
Suitable casing
I´ll put hundreds/thousands of those in peoples homes over the coming years, therefore external USB stick is not suitable.
/Hannes
normis
2
the RB922 has internal miniPCIe slot and SIM card for modems: http://routerboard.com/RB922UAGS-5HPacD
You can use it with this case, they fit nicely together: http://routerboard.com/CA411-711
If You need only 2.4Ghz and one Ethernet then BasBox2 would be good option. http://routerboard.com/RB912UAG-2HPnD-OUT
But you need 2.4Ghz and more then one Ethernet Then i would suggest geting RB953 http://routerboard.com/RB953GS-5HnT-RP
Plus 2.4Ghz card R11-2HnD http://routerboard.com/R11e-2HPnD
For LTE /4G modem I suggest you ME909u-521 Mini-PCIe http://consumer.huawei.com/en/solutions/m2m-solutions/products/tech-specs/me909u-521mini-pcie-en.htm
or Sierra Wireless MC7710 they both work very stable with our products
For rugged case i suggest you http://www.rfelements.com/en/products/radio-enclosures/stationbox-alu/
honzam
4
In this case (ca411-711) is place for SFP?
normis
5
You can see here, that behind the sticker is enough space:
New cases come woth appropriate stickers for RB911 and RB922
klaparp
6
Can i use a S-RJ01
RJ45 SFP 10/100/1000M copper module in te sfp port of RB922 and use it as second eth port?
Is that how it works?
/HW
klaparp
7
The Sierra MC7710 is discontiuned. Anyone tried a later model?
