Recommendation for CAPsMAN router device
i am designing a network of 6-10 VLANS (with filtered access in between VLANs) and 4-6 access points in my home, around 100 devices alltogether. Few VPN connections willcome on top.
If I understand CAPsMan correctly, fully centralized management (and advanatges) is achieved using forwarding mode which puts load on the router that runs CAPsMAN. In this scenario, however, switches cannot take much/any load as traffic within VLANS cannot be handled on switch level as forwarding mode runs on layer 3.
This makes me think that e.g. a CCR1016 (maxing out router capacity in my budget) would be beneficial over a combination of e.g. RB3011 + CSS326-24G-2S+RM where quite some budge would be spent into a switch that is not very useful in my setup.
Is my line of thinking correct ?
Lars
Hmm I was thinking the RB4011 as its quite powerful for the home scenario.
The unit you are thinking is like industrial grade lol.
I read about some difficulties, the 4011 has with VLANs?
Can I add a switch for a dedicated VLAN in forwarding mode? 10 ports is barely enough.
Lars
How much traffic (including inter-VLAN communication) are you going to route?
WAN connection is 300mbps (extension to 500 announced later this year). I would estimate internal traffic to be the same on top.
Lars
