Hello.. Do you have any recommendation to x86 hardware.
I am interested only 1U server hardware.. Exalple Dell, Hp etc. Need 4xSFP+ ports ( 2 x intel 82599 dual port cards)
How about Dell R320, R620?? Or is it better use older Rx10 series? Any other good hardware?
If you intend to install ROS on bare metal, then you better wait for ROS v7. It will come with greatly improved support for modern NICs. If you intend to run CHR, then HW support is up to Hypervisor you’re going to use.
In any case I’d go for CPU with smaller number of high-performance CPU cores … with HyperThreading disabled. Number of CPU cores help with huge number of parallel IP streams, faster cores help to achieve better single connection performance and some other tasks (such as BGP convergence). If you’ll go for a new server, then you won’t be able to get anything less than 6-8 CPU cores which would already make pretty powerful router.
Hiya.. we have some old R910 and R920.. 4 CPUs 10cores/20threads each cpu clock i think 2.6ghz or 2.8ghz will have to check.. i need to setup a CGNAT server for 2K with expansion up to 5k.. would i be better of running long-term v6.48.xx in bare metal no vmware wise.. or RoS v7? intel x520 dae is fully compatible with v6 routerOS? as we have tried some HP NCxxxx dual slot cards.. and it did not recognize neither in v6 or v7 beta
