Recommendation:
Recommendation:
In PPP ==>>sessions == >>above to add the maximum number of users
Normally use tick, one session per host, which means you could only authenticate once with PPPoE user name. Max sessions of cause if for some reason you want more then one PPPoE connection with same user name and password. In internet terms it is called concurrent connections.
