I’m looking for a recommendation for some antennas to use. I have NetMetal 5ac with a 2.4 GHz card in it. So a total of 5 RP-SMA antennas. 2 on 2.4 and 3 on 5Ghz. Right now I’m using junky rubber duck antennas, but I’m thinking they may be causing issues. I’m looking for some suggestions on alternatives. Either mimo patch, better ducks, or something else I can use. Any tips?
The only way to improve coverage in this case is adding more APs.
Using “super-antenna” on a single AP won’t help much.
(And don’t try to increase tx-power on you AP- that will make things work even worse)
