I live in a small town where the government provides free internet with these type of devices: https://i.imgur.com/a3kXqmB.jpg
I think they are Wavion WBS-2400. They are all 2.4ghz, they promised 5ghz APs but so far they are only in the bigger towns. I am currently using a TPLink TL-WA7210N to connect, but not very happy with the performance. This device has a “Throughput Monitor” option that shows a good “Receive” rate, but very poor “Transmit” rate. I am looking to replace the TL-WA7210N, and mikrotik seems to be a reputable brand on this field.
Here’s a map with the APs near me, im the blue dot, numbers on top of the antenna icons are the approximated distance in meters to me, number below it is just to ID them:
https://i.imgur.com/okPfFOQ.jpg
The TL-WA7210N is around 9 meters high, and currently pointing and connecting to AP 1, using the device “Survey” feature, I can also see the APs 2, 5 and 9 and some others if I point it to other directions, but AP 1 is the only one that seems to give a stable connection (but quite slow), most of the others doesn’t even give me an ip. I have LOS to some of the APs, but all with trees as obstacles.
My question is, what mikrotik products/devices/antenna would be a good replacement for my current tplink sh*t?
