Recommended hardware
We currently use a 450G box for vpns with eoip tunnels for each connection to stream 768K video to HD codecs.
We often have up to 15-20 simultaneous connections. Once in a while the cpu will jump to 100% and stay there, even after dropping all connections. Resources show there is still over half the memory available. Not sure entirely why this occurs, but we are thinking we should move to something bigger that can handle more connections.
Just curious what MikroTik product would be a good fit for what we are doing??
It would be one that is running version of ROS w/o the bug…Sound like your setup is triggering a bug so either update to the latest version or, if you’re using the latest version, send a message with supout.rif to support@mikrotik.com and have them check it out.
try to use BCP
M.
