Recommended requirments
What are the recommended requirements for Mikrotik in x86 for VMWare or Oracle Virtual Box?
Recommended RAM? and maximum ram size?
Recommended Hard Disk Space?
Recommended Processors? and maximum processors ?
Thank you.
128MB ram and the same hdd with whatever single core is enough to get it nicely work. The rest is about your load requirements…
If you’re running a virtual solution, go with CHR instead of x86. Resource requirements aren’t really any different, but the CHR is 64-bit versus x86 which is only 32-bit. Will make a difference if you’re running BGP or other high memory loads.
