Recommended routeros version for BGP multihoming
Folks,
which routeros version is recommended for a stable bgp multihoming setup with CCR1036-8G-2S+ router?
Thanks,
CS
Usually there are 2 versions available, the stable and long term.
The “current” versions are intended to add new features, that, to be honest, we don’t know if will work.
We will recommend you to use the long term version 6.45.9, because they put more attention on fixing bugs than deploying new features.
