Hello Every one
Our net providers install the router software. They told use password to me for any use in future. Unfortunately some change the admin password.
But they are trying to connect the router problem is raised.
I am see the some answers about reset password in mikrotik forum. They can say reinstall the is the best process.
I am reinstall the routuer software.
There are to interfaces
- LOM
- KRC
KRC interface is 192.168.1.1
LOM interface is 222.222.222.222
i am also add the default gatway ip\route \ some 222.222.222.222
This is the same configration of present router. From that router replay is comming from two towers in our network windows and router also.
But i am configured router reply is not comming from two towers in windows but from router reply is comming from tower1,tower2 and default gateway also. net was not comming what is the problem. Is there is any problem to install router software.
admin@mikriotik ping 222.220.227.222 (tower 1)
reply is comming.
but in windows ip of that system is (192.168.1.186)
ping 222.220.227.222 -t (tower 1)
reply is not comming.
tell me the solution as early as possible
plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz.
