If I have this current set up:
interface bridge vlan print detail
Flags: X - disabled, D - dynamic
0 bridge=BR1 vlan-ids=22 tagged=sfp1,sfp2 untagged=ether2 current-tagged=sfp2 current-untagged=""
1 bridge=BR1 vlan-ids=1005 tagged=sfp1,sfp2 untagged=ether3,ether4,ether5,ether6,ether7,ether8 current-tagged=sfp2
current-untagged=ether3,ether4
2 bridge=BR1 vlan-ids=1030 tagged=sfp1,sfp2 untagged=ether9,ether10,ether11,ether12 current-tagged=sfp2
current-untagged=ether10,ether12
3 bridge=BR1 vlan-ids=1006 tagged=sfp1,sfp2 untagged=ether13,ether14,ether15,ether16,ether17,ether18 current-tagged=sfp2
current-untagged=ether14,ether18,ether13,ether16
4 bridge=BR1 vlan-ids=1015 tagged=BR1,sfp1,sfp2 untagged=ether19,ether20,ether21,ether22 current-tagged=BR1,sfp2,sfp1
current-untagged=""
5 D bridge=BR1 vlan-ids=1 tagged="" untagged="" current-tagged="" current-untagged=BR1
Then what syntax do I need to change sfp1 from a trunk port to an access port on VLAN 1005? Do I need to re-write the whole VLAN table using the SET command and then set sfp1 as an access port? Not sure where to start. This is what I thought but no idea if it is correct. This switch is in production.
/interface bridge vlan
set bridge=BR1 tagged=sfp2 untagged=ether2 vlan-ids=22
ether3,ether4,ether5,ether6,ether7,ether8,sfp1 vlan-ids=1005
ether9,ether10,ether11,ether12 vlan-ids=1030
ether13,ether14,ether15,ether16,ether17,ether18 vlan-ids=1006
set bridge=BR1 tagged=BR1,sfp2 untagged=
ether19,ether20,ether21,ether22 vlan-ids=1015
#Then I need to set sfp1 as an access port on Vlan 1005, I think:
set bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged
ingress-filtering=yes interface=sfp1 pvid=1005
