Reconfiguring the default Ethernet switch config on a 750G
I would like to reconfigure the default Ethernet switch on a 750G to remove all ports from the switch.
I consistently kick myself out of the RB750G by playing around with reassinging master port.
What’s the deal?
f.
You can do
/system reset-configuration no-defaults=yes
And default configuration will not be applied after reset. Also you can simply reset configuration and choose to remove configuration when you get prompted.
I managed to get it working by dancing around the config.
When it resets, does it reset without the ports as part of a switch?
f.
No, unless you specify
no-defaults=yes
Also after each configuration reset RouterOS will prompt you after first login whether you want to save default configuration or not.
