record traffic script not working
cannot seem to get this script to work wont run . what is wrong with it ( what did i do incorrectly)
:global tmp :global tx :global rx :foreach i in [/interface find] do={/interface monitor-traffic $i once do={:set tx ($sent-bits-per-second/1048576):set rx ($received-bits-per-second/1048576):if ([/system scheduler get record run-count]=1) do={:global ttx :set ttx $tx :global trx :set trx $rx}:if ($tx>$ttx) do={/tool e-mail send to=example@example.com subject=“Script message” body=("The transmission traffic on " .[/interface get $i name] . " got up to " . $tx . “Mbps”):set ttx $tx}:if ($rx>$trx) do={/tool e-mail send to=example@example.com subject=“Script message” body=("The receiving traffic on " . [/interface get $i name] . " got up to " . $rx . “Mbps”):set trx $rx}}}
Randy
missed space before [/interface get $i…]
thanks fixed the script
is there a way to watch the script to see each step works or doesnt?
you can use ‘:log’ command after each step. In the ‘/log’ then see whether every :log is executed correctly.
Edgars
do i put the :log after each command?
Randy
Randy
The best way would be regression testing :slight_smile:
Start with the general statement like:
:foreach i in [/interface find] do={:put $i}
Then add some more complexity:
:foreach i in [/interface find] do={/interface monitor-traffic $i once do={:put $i; :environment print;}}
Fix the code before doing something else:
:foreach i in [/interface find running=yes] do={/interface monitor-traffic $i once do={:put $i; :environment print;}}
Hint: you can run the script direcly from the console, without creating /system script entry. Just copy-paste the code to the console
Test individual pieces of code separately.
thanks for the info . will play with this in the morning
Randy
This script send to log source address and destination address?
For each lan port or wireless?
10x.
OrCAD
