Recover hAP
I tried to update an hAP to 6.36.
After it rebooted, it did not appear again in winbox.
How do I recover it?
Which steps do I need to do to inject npk packet in it via Netinstall?
I tried a lot of procedures:
  • hold res/wps for 30 seconds while it is powered on;
  • hold res/wps before the hAP power on and keep held about 30 seconds;
  • hold res/wps before the hAP power and release after LED turned off
:confused:
Are you accessing it via wireless? Did you switch the wireless package before upgrading?
It should still be accessible on wired ethernet.
I’m trying to access it via ethernet cable.
The wireless is down, my notebook do not find it.
It seems the RB has dead, Winbox do not find it.
Thanks.
:slight_smile:
It worked!
  1. I plugged my ethernet cable in eth1
  2. I waited it to power on
  3. I pressed the res/wds button about 1min
  4. It appeared in netinstall 6.36
  5. Then I installed routeros-smips in it.
:smiley:
