My RB450 won’t boot.
While I have found a lot of information online, nothing I have found seems to match my circumstances.
I was given this old RB450. It was working fine, running RouterOS 4.9. The Webfig interface was very different to the newer models I am familiar with - it had a minimal horizontal menu structure.
So I downloaded an update - went for an older version, thinking it might be better with my older hardware - routeros-mipsbe-6.21.npk
The file uploaded and I clicked the install (or similar) button. Since then, the RB450 has not booted.
I’ve got a serial console going. This is the output when I attempt to boot:
RouterBOOT backup booter 3.02
RouterBoard 450
CPU frequency: 300 MHz
Memory size: 64 MiB
NAND size: 128 MiBPress any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
ERROR: no system package found!
Kernel panic - not syncing: Attempted to kill init!
Rebooting in 1 seconds..
Details of the board are:
your choice: i - board info
Board Info:
Board type: 450
Serial number: 36E002C01507
Firmware version: 3.02
Memory size: 64 MB
Build time: 2012-11-30 17:04:49
eth1 MAC address: D4:CA:6D:9C:B8:1E
eth2 MAC address: D4:CA:6D:9C:B8:1F
eth3 MAC address: D4:CA:6D:9C:B8:20
eth4 MAC address: D4:CA:6D:9C:B8:21
eth5 MAC address: D4:CA:6D:9C:B8:22press any key to continue…
I wondered if I need to update my bootloader to match the RouterOS that I uploaded? Uploading it would be OK, if I could find a file. I’ve not found anywhere to download an updated bootloader.
Obvious option would be downgrade the RouterOS back to 4.9, but I can’t see a way to do that in the serial interface.
Can someone please ether give me some steps to get my RB450 out of this pickle, or point me to instructions that clearly show the steps and how to find the files for this model?
Cheers! Steve
