Hi every one…
I have omnitik u-5hnd with routeros 5.25.I wanted to downgrade it to 4.17 and when I did that I lost access to the unit.I followed instruction concerning the recovery procedure with no luck.I turned off the device and held the reset button for 25 seconds to make the device look for Netinstall server with no luck.please help me
thanks
See to my website for the correct netinstall procedure.
Disable firewall on your PC
http://www.wirelessinfo.be/index.php/mikrotik/pages/netinstalle
Many thanks.
Thank you very musch master.I recovered the unit successfully ![]()
Good to hear that
If you want give me karma please
