Hello
I have Mikrotik N2458 0.05
I have set ALL interfaces (radio and ethernet) in shutdown.
I’m not able to connect with my Mikrotik… ![]()
Can you help me?
Regards
Hello
Can you help me?
Regards
use console cable
Open the antenna unit to gain physical access to the Mikrotik RouterBoard. Then connect a serial cable like this and fix your mistake.
http://www.roc-noc.com/product.php?productid=58&cat=8&page=1
Tom
Hi!
Thanks for reply.
In my Mikrotik Nebula I have only one port ethernet from outside.
Can’t recovery it without open the Nebula device?
http://www.flycommunications.net/download2.php?filename=N2458+0.05.pdf1227874554
thanks
Solved opening it and using serial cable
Thanks agin!
