Hello folks!
Me again bugging, if someone is kind enough to share some wisdom on a very annoying problem i´ve been dealing with, on my RB2011UiAS-
first things first my config:
# jul/04/2022 18:36:11 by RouterOS 7.3.1
# software id = B2RC-819H
# model = RB2011UiAS
# serial number = 00000000000
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled \
frequency=2422 name=channel1
frequency=2432 name=channel6
frequency=2447 name=channel9
frequency=2457 name=channel12
add admin-mac=11:22:33:AA:BB:CC auto-mac=no name=bridge1
set [ find default-name=ether1 ] comment="WAN1 - IPLAN" loop-protect=on \
loop-protect-disable-time=1m
set [ find default-name=ether2 ] comment="WAN2 - FIBERCORP" loop-protect=on
set [ find default-name=ether5 ] comment="LAN - switch Trunk to TPLINK" \
loop-protect=on
/caps-man configuration
add channel.band=2ghz-g/n .control-channel-width=20mhz country=argentina \
datapath.bridge=bridge1 .client-to-client-forwarding=no \
.local-forwarding=no name=configuracion_barentz \
security.authentication-types=wpa-psk,wpa2-psk .encryption=aes-ccm,tkip \
.group-key-update=1d ssid="Wifi Barentz"
/caps-man interface
add channel=channel6 configuration=configuracion_barentz disabled=no l2mtu=\
1600 mac-address=DC:2C:6E:64:9E:27 master-interface=none name=cap1 \
radio-mac=DC:2C:6E:64:9E:27 radio-name=DC2C6E649E27
add channel=channel12 configuration=configuracion_barentz disabled=no l2mtu=\
1600 mac-address=DC:2C:6E:64:A0:55 master-interface=none name=cap2 \
radio-mac=DC:2C:6E:64:A0:55 radio-name=DC2C6E64A055
add channel=channel1 channel.frequency=2412 configuration=\
configuracion_barentz disabled=no l2mtu=1600 mac-address=\
DC:2C:6E:64:9F:57 master-interface=none name=cap4 radio-mac=\
DC:2C:6E:64:9F:57 radio-name=DC2C6E649F57
add channel=channel9 configuration=configuracion_barentz disabled=no l2mtu=\
1600 mac-address=DC:2C:6E:64:9F:33 master-interface=none name=cap5 \
radio-mac=DC:2C:6E:64:9F:33 radio-name=DC2C6E649F33
/interface lte apn
add name=dhcp_pool1 ranges=192.168.101.2-192.168.101.254
add address-pool=dhcp_pool1 interface=bridge1 lease-time=1d name=dhcp1
/port
set 0 name=serial0
/queue type
add kind=pcq name=DOWN pcq-classifier=dst-address
add kind=pcq name=UP pcq-classifier=src-address
/queue tree
add name="WAN1 DOWN" parent=global queue=default
add name="WAN1 UP" parent=ether1 queue=default
add name="WAN1 - WEB - rx" packet-mark=web-wan1 parent="WAN1 DOWN" priority=3 \
queue=DOWN
add name="WAN1 - WEB- tx" packet-mark=web parent="WAN1 UP" priority=3 queue=\
UP
add name="WAN1 - DNS - rx" packet-mark=dns-wan1 parent="WAN1 DOWN" priority=2 \
queue=DOWN
add name="WAN1 - DNS - tx" packet-mark=dns parent="WAN1 UP" priority=2 queue=\
UP
add name="WAN1 - ICMP -rx" packet-mark=icmp-wan1 parent="WAN1 DOWN" priority=\
1 queue=DOWN
add name="WAN1 - ICMP - tx" packet-mark=icmp parent="WAN1 UP" priority=1 \
queue=UP
add name="WAN1 - QUIC - rx" packet-mark=quic-wan1 parent="WAN1 DOWN" \
priority=5 queue=DOWN
add name="WAN1 - QUIC -tx" packet-mark=quic parent="WAN1 UP" priority=5 \
queue=UP
add name="WAN2 DOWN" parent=global queue=default
add name="WAN2 UP" parent=ether2 queue=default
add name="WAN2- DNS - rx" packet-mark=dns-wan2 parent="WAN2 DOWN" priority=2 \
queue=DOWN
add name="WAN2 - DNS -tx" packet-mark=dns parent="WAN2 UP" priority=2 queue=\
UP
add name="WAN2 - ICMP - rx" packet-mark=icmp-wan2 parent="WAN2 DOWN" \
priority=1 queue=DOWN
add name="WAN2 - ICMP -tx" packet-mark=icmp parent="WAN2 UP" priority=1 \
queue=UP
add name="WAN2 - QUIC - rx" packet-mark=quic-wan2 parent="WAN2 DOWN" \
add name="WAN1 - QUIC - tx" packet-mark=quic parent="WAN2 UP" priority=5 \
queue=UP
add name="WAN2 - RESTO - rx" packet-mark=resto-wan2 parent="WAN2 DOWN" queue=\
DOWN
add name="WAN2 - RESTO - tx" packet-mark=resto parent="WAN2 UP" queue=UP
add name="WAN2 - WEB - rx" packet-mark=web-wan2 parent="WAN2 DOWN" priority=3 \
queue=DOWN
add name="WAN2 - WEB - tx" packet-mark=web parent="WAN2 UP" priority=3 queue=\
UP
add name="WAN1 - Resto -rx" packet-mark=resto-wan1 parent="WAN1 DOWN" queue=\
DOWN
add name="WAN1 - Resto - tx" packet-mark=resto parent="WAN1 UP" queue=UP
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing table
add disabled=yes fib name=to_ISP1
add disabled=yes fib name=to_ISP2
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge1
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=configuracion_barentz
add bridge=bridge1 ingress-filtering=no interface=ether3
add bridge=bridge1 ingress-filtering=no interface=ether4
add bridge=bridge1 ingress-filtering=no interface=ether5
add bridge=bridge1 ingress-filtering=no interface=ether6
add bridge=bridge1 ingress-filtering=no interface=ether7
add bridge=bridge1 ingress-filtering=no interface=ether8
add bridge=bridge1 ingress-filtering=no interface=ether9
add bridge=bridge1 ingress-filtering=no interface=ether10
set discover-interface-list=all
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.101.1/24 comment="LAN SUBNET" interface=bridge1 network=\
192.168.101.0
add address=x.x.x.x/24 comment="IPLAN STATIC IP" interface=ether1 \
network=x.x.x.x
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
/ip dhcp-client
add add-default-route=no disabled=yes interface=ether2 use-peer-dns=no \
use-peer-ntp=no
/ip dhcp-server lease
add address=192.168.101.249 client-id=1:dc:2c:6e:64:a0:54 mac-address=\
DC:2C:6E:64:A0:54 server=dhcp1
add address=192.168.101.247 client-id=1:14:eb:b6:ce:de:ff mac-address=\
14:EB:B6:CE:DE:FF server=dhcp1
add address=192.168.101.251 client-id=1:dc:2c:6e:64:9e:26 mac-address=\
DC:2C:6E:64:9E:26 server=dhcp1
add address=192.168.101.248 client-id=1:dc:2c:6e:64:9f:32 mac-address=\
DC:2C:6E:64:9F:32 server=dhcp1
add address=192.168.101.253 client-id=1:48:5b:39:a3:ed:a3 mac-address=\
48:5B:39:A3:ED:A3 server=dhcp1
add address=192.168.101.250 client-id=1:dc:2c:6e:64:9f:56 mac-address=\
DC:2C:6E:64:9F:56 server=dhcp1
add address=192.168.101.0/24 dns-server=192.168.101.1 gateway=192.168.101.1
set allow-remote-requests=yes max-udp-packet-size=512 query-server-timeout=1s \
servers=8.8.4.4,8.8.8.8
/ip firewall address-list
add address=192.168.101.0/24 list=LocalLan
add address=x.x.x.x/24 list=SubnetWAN1
add address=y.y.y.y/24 list=SubnetWAN2
add address=cloud.mikrotik.com list=Cloud
add address=cloud2.mikrotik.com list=Cloud2
add action=accept chain=input dst-port=8291 protocol=tcp
add action=accept chain=input comment="Alow access Router from LAN" \
src-address-list=LocalLan
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=accept chain=forward comment="allow conn from LAN" \
connection-state=new in-interface=bridge1
add action=accept chain=forward comment="allow established" connection-state=\
established
add action=accept chain=forward comment="allow related" connection-state=\
related
add action=drop chain=forward comment="drop all fwd"
add action=accept chain=input comment="allow established to router" \
connection-state=established
add action=accept chain=input comment="allow related to router" \
connection-state=related
add action=drop chain=input comment="Dropp all to router"
/ip firewall mangle
add action=mark-connection chain=input comment="Mark Routing - WAN1" \
in-interface=ether1 new-connection-mark=WAN1 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1 new-routing-mark=\
main passthrough=no
add action=mark-connection chain=input comment="Mark Routing - WAN2" \
in-interface=ether2 new-connection-mark=WAN2 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN2 new-routing-mark=\
main passthrough=no
add action=mark-connection chain=prerouting comment="Mark WEB" \
new-connection-mark=web port=80,443 protocol=tcp
add action=mark-packet chain=prerouting connection-mark=web in-interface=\
ether1 new-packet-mark=web-wan1 passthrough=no
ether2 new-packet-mark=web-wan2 passthrough=no
add action=mark-packet chain=prerouting connection-mark=web new-packet-mark=\
web passthrough=no
add action=mark-connection chain=prerouting comment="Mark DNS" \
new-connection-mark=dns port=53 protocol=udp
add action=mark-connection chain=prerouting new-connection-mark=dns port=53 \
protocol=tcp
add action=mark-packet chain=prerouting connection-mark=dns in-interface=\
ether1 new-packet-mark=dns-wan1 passthrough=no
ether2 new-packet-mark=dns-wan2 passthrough=no
add action=mark-packet chain=prerouting connection-mark=dns new-packet-mark=\
dns passthrough=no
add action=mark-connection chain=prerouting comment="Mark ICMP" \
new-connection-mark=icmp protocol=icmp
add action=mark-packet chain=prerouting connection-mark=icmp in-interface=\
ether1 new-packet-mark=icmp-wan1 passthrough=no protocol=icmp
ether2 new-packet-mark=icmp-wan2 passthrough=no protocol=icmp
add action=mark-packet chain=prerouting connection-mark=icmp new-packet-mark=\
icmp passthrough=no protocol=icmp
add action=mark-connection chain=prerouting comment="Mark QUIC" \
new-connection-mark=quic port=443 protocol=udp
add action=mark-packet chain=prerouting connection-mark=quic in-interface=\
ether1 new-packet-mark=quic-wan1 passthrough=no protocol=udp
add action=mark-packet chain=prerouting connection-mark=quic new-packet-mark=\
quic passthrough=no protocol=udp
ether2 new-packet-mark=quic-wan2 passthrough=no protocol=udp
add action=mark-connection chain=prerouting comment="Mark RESTO" \
new-connection-mark=resto
add action=mark-packet chain=prerouting connection-mark=resto in-interface=\
ether1 new-packet-mark=resto-wan1 passthrough=no
add action=mark-packet chain=prerouting connection-mark=resto \
new-packet-mark=resto passthrough=no
ether2 new-packet-mark=resto-wan2 passthrough=no
add action=masquerade chain=srcnat comment="Masquerade - WAN1" out-interface=\
ether1 src-address-type=""
add action=masquerade chain=srcnat comment="Masquerade - WAN2" out-interface=\
ether2
add comment="Monitor Ext Host Via ISP1" disabled=yes distance=1 dst-address=\
1.1.1.1/32 gateway=x.x.x.x pref-src=0.0.0.0 routing-table=main \
scope=10 suppress-hw-offload=no target-scope=10
add comment="Monitor Ext Host Via ISP2" disabled=yes distance=1 dst-address=\
1.0.0.1/32 gateway=y.y.y.y pref-src=0.0.0.0 routing-table=main \
add comment="Default Route - Main" disabled=no distance=1 dst-address=\
0.0.0.0/0 gateway=x.x.x.x pref-src=0.0.0.0 routing-table=main \
scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping comment="Default Route - Backup" disabled=yes \
distance=2 dst-address=0.0.0.0/0 gateway=1.0.0.1 pref-src=0.0.0.0 \
routing-table=main scope=30 suppress-hw-offload=no target-scope=11
add comment="Monitor Ext Host Via ISP1*" disabled=yes distance=1 dst-address=\
208.67.222.222/32 gateway=x.x.x.x pref-src="" routing-table=main \
add comment="Monitor Ext Host Via ISP2*" disabled=yes distance=1 dst-address=\
208.67.220.220/32 gateway=y.y.y.y pref-src="" routing-table=main \
/lcd
set default-screen=informative-slideshow
/system clock
set time-zone-name=America/Argentina/Buenos_Aires
/system identity
set name=Barentz
/system logging
add action=disk topics=critical
add action=disk topics=error
add topics=event
add action=disk topics=event
add action=disk topics=info
add topics=interface
add action=disk topics=interface
add topics=script
add action=disk topics=script
add topics=state
add action=disk topics=state
add action=disk topics=warning
add topics=caps
add action=disk topics=caps
add prefix="Route Changes" topics=route
add action=disk prefix="Route Changes" topics=route
/system ntp client
set enabled=yes
/system ntp client servers
add address=104.171.113.34
add address=162.159.200.1
my current config is hardcoded to NO check-gateway ping, since its unbearebly inconsistent… as for the 2nd ISP, its was on DHCP (ISP hasnt decided to provide a static IP yet) and it was making my config even more complicated to manage, so its single threaded as of today.
am i missing anything obvious? the setup look correct in theory (help Mikrotik, google, guides, etc) but this really throws me off, and im unable to understand what is wrong here:
Route Changes: 2.2 Merge forwarding path updates
Route Changes: Prepare queued IP/1.1.1.1/30-11/2
Route Changes: Disqualified fwp IP/1.1.1.1/30-11/2
Route Changes: Resolving IP/1.1.1.1/30-11/2
Route Changes: Resolve as unreachable, gateway is not active
2 min later it recovers…
Route Changes: Resolved link IP/1.1.1.1/30-11/2 via 1.1.1.1->IP/x.x.x.x/11-10/0 FLD{1} rr tr has metric BEST/32
I cant possible fhatom the idea of Softlayer DNS being THIS unstable…
any idea or help is appreciated.
Thanks!
