Good evening all,
I am about to configure Recursive Failover on my CCR with dual WAN. The reason I am making this configuration is because my primary ISP connection has many hops before the main router and the gateway i use is not the gateway of the main router. This means if any link between my gateway adn the main router fails i do not detect the drop with a standard ping check.
This is what I am planning to do:
add dst-address=8.8.4.4/32 gateway=10.0.1.1 scope=10 comment=“Validate Primary”
add gateway=8.8.4.4 distance=1 check-gateway=ping comment=Primary
add gateway=10.0.2.1 distance=2 comment=Secondary
By doing this it should check my gateway by checking if the internet is available by doing a ping to Google DNS server.
This is all good, but does anyone know how many pings have to be lost before it disables the gateway? I am worried that sometime you can loose a ping to google and i dont want it to be changing over every time one or two pings are lost to Google DNS…
