Recursive gateway and VPN
Hi
I have a mikrotik router with two WAN (StarLink gateway 1 and a local ISP gateway 2) with recursive gateway
I also have wireguard VPN and the problem is that the first Gateway (StarLink) doesnt allow port forwarding
I need to know if there is any way to route VPN traffic in my second gateway
I think as long as you have your Wireguard service attached to the proper gateway you should do fine.
It would help to see your current config:
/export file=anynameyoulike
Remove serial and any other private info, post as Preformatted text by using the </> button
You can create two routing tables, and choose one using policy-based routing (i.e. when source address belongs to your VPN network, you use second routing table with default gateway2).
port forwarding
Do you mean uPnP?
GoodMorning
My configuration is like that
add name=bridge1 port-cost-mode=short
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
set [ find default-name=wlan2 ] ssid=MikroTik
/interface wireguard
add listen-port=13231 mtu=1420 name=wg1
/interface lte apn
add name=dhcp_pool0 ranges=192.168.11.2-192.168.11.254
add address-pool=dhcp_pool0 interface=bridge1 lease-time=10m name=dhcp1
/routing table
add disabled=no fib name=to_OTE
add bridge=bridge1 ingress-filtering=no interface=ether3 internal-path-cost=
10 path-cost=10
add bridge=bridge1 ingress-filtering=no interface=ether4 internal-path-cost=
10 path-cost=10
set udp-timeout=10s
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
add auth=sha1,md5 mac-address=FE:EB:F6:8F:CF:C1 name=ovpn-server1
/interface wireguard peers
add allowed-address=192.168.100.2/32 interface=wg1 name=test public-key=
"xxxxxxx"
add address=192.168.1.2/24 interface=ether2 network=192.168.1.0
add address=192.168.10.2/24 interface=ether1 network=192.168.10.0
add address=192.168.11.1/24 interface=bridge1 network=192.168.11.0
add address=192.168.100.1/24 interface=wg1 network=192.168.100.0
/ip cloud
set ddns-enabled=yes
add address=192.168.11.0/24 gateway=192.168.11.1
set servers=1.1.1.1,1.0.0.1
/ip firewall mangle
add action=mark-routing chain=prerouting connection-mark=no-mark
new-routing-mark=to_OTE src-address=192.168.100.0/24
add action=masquerade chain=srcnat out-interface=ether2
/ip hotspot profile
/ip ipsec profile
add disabled=no distance=1 dst-address=8.8.8.8/32 gateway=192.168.10.254
routing-table=main scope=10 suppress-hw-offload=no target-scope=10
add disabled=no dst-address=1.1.1.1/32 gateway=192.168.1.1 scope=10
add check-gateway=ping disabled=no dst-address=0.0.0.0/0 gateway=8.8.8.8
target-scope=11
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=
1.1.1.1 target-scope=11
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.1.1
routing-table=to_OTE suppress-hw-offload=no
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=Europe/Athens
/system routerboard settings
set auto-upgrade=yes
