This is my working routing table in rOS V6:
add comment="Failover host2" disabled=no distance=1 dst-address=1.1.1.1/32 gateway=192.168.200.1 pref-src="" routing-table=main scope=10 suppress-hw-offload=no target-scope=10
add comment="Failover host1" disabled=no distance=1 dst-address=8.8.4.4/32 gateway=192.168.200.1 pref-src="" routing-table=main scope=10 suppress-hw-offload=no target-scope=10
add check-gateway=ping comment="Failover virtualhost1" disabled=no distance=1 dst-address=10.17.13.1/32 gateway=8.8.4.4 pref-src="" routing-table=main scope=10 suppress-hw-offload=no target-scope=10
add check-gateway=ping comment="Failover virtualhost2" disabled=no distance=1 dst-address=10.17.13.1/32 gateway=1.1.1.1 pref-src="" routing-table=main scope=10 suppress-hw-offload=no target-scope=10
add comment="Failover gwa" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.17.13.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
that works no more in rOS V7
First two rules to route 1.1.1.1 and 8.8.4.4 to real router 192.168.200.1
second two rules for ping-checking with dummy gw 10.17.13.1 to be used as default route on fifth route
What to do ?
Thank you
