Redirect connection to static webpage with Radius
Hi Guys,
We use a custom radius server to authenticate PPPoE connections on our network.
We are working on a solution where we can disconnect a user and redirect there connection to a static webpage when we require.
Does anyone know of any way that you can force a connection to a specific website either via radius attributes (doubt this is possible) or using the MikroTik API to do something fancy?
Basically, we are trying to force specific connections through to a Walled Garden Landing Page, much like you would with a hotspot.
Just looking for pointers on where to look moving forward.
Thanks Guys.
Using radius-CoA you can command a redirect from the server. Question is, whether client (Mikrotik) supports it.
This sounds very interesting. Does anyone know if MikroTik support this? Or do we have a MikroTik solution that performs a similar job?
Thanks Guys.
