Hi all,
Ive been using the following lines to prevent users from using their own dns settings:
/ip firewall
add action=dst-nat chain=dstnat dst-port=53 log-prefix="" protocol=tcp to-addresses=37.235.1.174 to-ports=53
add action=dst-nat chain=dstnat dst-port=53 log-prefix="" protocol=udp to-addresses=37.235.1.174 to-ports=53
so if a user sets 8.8.8.8 it will force the use of 37.235.1.174
Now I want to use my PiHole as default DNS setting, so I set the DHCP Network as follows:
(PiHole is set to use 37.235.1.174)
add address=192.168.22.0/24 dns-server=192.168.22.254 domain=KITMIKRO.LAN gateway=192.168.22.1 netmask=24
the user now gets the default DNS 192.168.22.254 and benefits from the pihole and 37.235.1.174
Unless the user sets it’s own DNS to 8.8.8.8, then they wil skip the PiHole.
I can’t seem to think of a way of redirecting through the Pi-Hole
It’s probably something easy and I am at this for to long… So how do I do this?
