redirect popup on vista
Hello I tried to setup the redirect function in Hotspot User Profile.
It is not working because when timer expires a new window is open with this address: http://10.3.0.1/www.xyz.com and gives HTTP404 page not found.
Transparent Proxy is set to yes so I have no other ideas to solve this problem.
I think the problem is due to some setting in IE7 in Windows Vista.
Please have you any idea on how to solve this problem?
Many thanks and regards
Alessandro
paste your hotspot profile config please, looks like you entered something incorrectly
Hi Normis, thanks for your reply; below I’ll paste the hotspot config and also the user profile used to do these tests:
name=“hsprof1” hotspot-address=10.3.0.1 dns-name=“” html-directory=hotspot
rate-limit=“” http-proxy=0.0.0.0:0 smtp-server=0.0.0.0
login-by=cookie,http-chap,trial http-cookie-lifetime=3d
split-user-domain=no trial-uptime=30m/1d trial-user-profile=default
use-radius=no
name=“utenti_basso” address-pool=pool2 session-timeout=5m
idle-timeout=none keepalive-timeout=2m status-autorefresh=1m
shared-users=1 rate-limit=“32k/320k” transparent-proxy=yes
open-status-page=always advertise=yes advertise-url=www.systelnet.it
advertise-interval=1m advertise-timeout=immediately
Hope this reveals my mistake.
many thanks and regards
Alessandro
up
try to add http:// to make it a proper URL
