redirect pppoe users to isp homepage
hi! i would like to know if there´s any dst nat rule that can match the first conection to port 80 from a pppoe subscriber to redirect to another web server ( another port) with the default isp home page?
first connection? and what to do with others?..
first tcp conection to port 80 from each pppoe client. the others go normal without the dst nat rule to our isp homepage
I think it is not possible.
  1. It is not possible, correctly to forward to specific page with NAT rules.
  • It could be possible with DNS, proxy, but not with NAT rules.
  1. The one feature is HotSpot that I could imagine, where you have advertisement (but you are using PPPoE).
can i use hotspot and pppoe at same time ?
Yes, you can use pppoe and hotspot as i use it for 2 years.
if a client dont pay you can block him in hotspot or you can point it to the hotspot homepae which already change it to for example “you should call sales dep.”
