Good morning,
I hope you can help me to solve this problem. have this situation:
A Vodafone router (ISP) where mikrotik router is connected lan-wan connection.
mikrotik is connected to the vodafone router with address 192.168.1.2, while from the miktronik router there are two lan networks, one 192.168.10.0 and the other 192.168.20.0.
Internet connection work, i try to block same sites and work, I only have the problem to redirect to a specific url when, for example, they try go on facebook site.
I’ve tried it via web proxy but it doesn’t work for me. I use this settings:
web proxy: enable on port 8080
I went to “access” propertie and I created a rule where dst.host is www.facebook.com, action: deny, redirect to: www.google.it.
then I went to the firewall, then to nat, and entered another rule:
chain: dstnat, port: 80, protocol: tcp, action: redirection, to ports: 8080
where i wrong?
