redirect proxy
hi all
i am a beginner in mikrotik, i am sorry before my english is not good
i find a problem when i want to redirect request (www/port 80) to my proxy server (linux/port:8080) in another manchine behind the router
topology like this
internet---- mikrotik router (2 NIC)----proxy server (linux/1 NIC) —Client
Mikrotik / static route:
Ether1: public ip from ISP (204.x.x.x)
Ether2: public ip that i register to apnic (indonesia)…203.x.x.1/29 and everything no problem, without proxy i cant browsing to internet
Proxy:
eth0:public ip…203.x.x.2/29
Client:
203.x.x.8/29 gateway 203.x.x.1
203.x.x.16/29 gateway 203.x.x.1
i want to configure proxy as transparant proxy
any one give advice what should i do in mikrotik router or give me link who i can learn more
thank you very much for advice
HI, you must to configure parent proxy on the MT
hi,
thanks for the answer, but i am still confuse, how to configure parent proxy in mikrotik, i am sorry i am a beginner in mikrotik, or could i get a link about parent proxy in mikrotik, so i can read that
thank you
Check this links: http://www.mikrotik.com/docs/ros/2.9/ip/proxy ,http://www.mikrotik.com/docs/ros/2.9/ip/webproxy
Hi mr.cibernet
i have try the url that you give to me http://www.mikrotik.com/docs/ros/2.9/ip/proxy ,http://www.mikrotik.com/docs/ros/2.9/ip/webproxy
but when i try that link i cant access the internet, when i see on my linux squid box (tail -f /usr/local/squid/var/logs/access.log) thereis nothing,
this is my configure in Mikrotik Router
/ip firewall dst-nat
add src-address=0.0.0.0/0 in-interface=ether2 dst-address=203.x.x.x/24 protocol=tcp action redirect to-dst-port=8088 disabled=no
/ip web proxy
set enabled=yes src-address=0.0.0.0 port 8088 hostname=“proxy” transparent-proxy=yes parent-proxy=203.x.x.10(my squid proxy server):8088 cache-administrator=“ketut” max-object-size=0 cache-drive=system max-cache-size=none
is there something wrong with my configuration??? i am very thanks you very much for your answer, or could you give configuration example for my case??
thank you
Do you have nat on the MT box? you should have an IP eth1 public, and then eth2 private IP…
The redirect rule (assuming you have NAT and a private network of 192.168.0.0/24)
add chain=dstnat src-address=192.168.0.0/24 protocol=tcp dst-port=80 action=redirect to-ports=8088
thank you mr cibernet for the answer
my topology network (ISP) dont use NAT,
Mikrotik router have 2 NIC, 1 NIC connect to our provider(202.x.x.x), 1 NIC use 203.x.x.1/this ip i get from apnic) n my client get ip public 203.x.x.x/24…n then my proxy server used 203.x.x.2, i want my client (203.x.x.x) use my proxy to connect to website (transparant proxy)
if the configuration like that mikrotik router can solved the problem??? i am sorry mr cibernet this is my first time use mikrotik, i am very thank you for your guidance…i am very sorry too my english is not good
pls try my configuration 4 ur problem
http://forum.mikrotik.com//viewtopic.php?t=6639
thank you very much for your advice
i will try mr. tuyulireng
btw, are u indonesian? if yes can we talk indonesia, so when i got a problem i can consult with you
thanks ones again
Sama2 mr. Ketut.
Saya juga baru banget mengenal mikrotik.
hai pak siapa nih biar enak panggilnya
saya juga masih belajar nih pak…mohon bantuannya
belajar sama sama
panggil aja be, ada YM ??? biar enak
Speak in english please…
maaf pak be baru bisa saya balas
id YM saya: uzrox77
kalo bapak?
to Mr.cibernet… i am very very sorry, i am use indonesian language…thats mean mr. tuyul ireng want to know my ym id
thanks
