I completely understood your problem from the first post. This IS a hairpin Nat situation. Remember that in reality, there is no such thing as a LAN or WAN interface of a Router. All interfaces are just ways to go, and there are addresses in various directions.
Hairpin means that the destination of the NAT is out the same interface from which the packet was received.
It doesn’t mean LAN host talking via pinhole on wan IP to another LAN host. (sure, that’s over 99% of the cases you see in the forums, but technically, hairpin can be a wan host talking to another wan host)
Here’s why you must have a masquerade rule:
Let’s say your computer “somewhere on the internet” has IP 9.9.9.9, the Mikrotiks have the given addresses of 10.10.10.11 and 11.11.11.11 from your example.
You type 10.10.10.11 (or some hostname for that IP) into your browser.
Packet leaves your computer with src/dst IP:
9.9.9.9 / 10.10.10.11
Packet hits first mikrotik and gets dst-nat - (but no masquerade) - and leaves with:
9.9.9.9 / 11.11.11.11
Packet arrives at server
Server replies to sender’s IP with a packet whose src/dst addresses are:
11.11.11.11 / 9.9.9.9 (see the problem yet?)
PC receives a TCP SYN+ACK packet from this un-known host 11.11.11.11 (it was trying to talk to 10.10.10.11)
PC discards this invalid SYN/ACK packet from this weirdo 11.11.11.11 host
PC wonders why 10.10.10.11 hasn’t answered yet, re-sends the TCP SYN to 10.10.10.11
Packet bounces around the triangle, and again makes it back to PC with the wrong source address.
PC drops all following SYN/ACK packets from 11.11.11.11 just like the first one
PC wonders what’s wrong with 10.10.10.11
PC gives up on 10.10.10.11 and shows a “Website cannot be displayed” error on your screen.
You come to forums and ask what’s wrong.
And here we are.
Now on the 10.10.10.11 Mikrotik, make a nat rule in the srcnat chain which matches out-interface=wan dst-address=11.11.11.11 action=src-nat to-addresses=10.10.10.11
Here’s what will happen when you try again after adding that rule to the Mikrotik:
Now the packet leaves your PC with src/dst IP addresses:
9.9.9.9 / 10.10.10.11 (same so far)
Packet leaves the first mikrotik:
10.10.10.11 / 11.11.11.11 (different, thanks to new srcnat rule)
Server replies with packet:
11.11.11.11 / 10.10.10.11 (packet now heading back to Mikrotik)
Mikrotik un-nats this packet and sends it to you as:
10.10.10.11 / 9.9.9.9
Now your PC sees the SYN/ACK from the correct remote host, completes the handshake, requests the web page, draws it on your screen.
You smile, and come back here and mark + karma on this reply.
(hehe - seriously, if this doesn’t fix, I’ll keep helping though)
I hope this illustrates why it’s still hairpin even with public IPs. It has nothing to do with public/private IP, and nothing to do with wan/lan. It has everything to do with packets arriving at the server and client with addresses that will cause the packets to flow the way they need to. Basically, without the hairpin rule, the Mikrotik never gets the chance to un-do the NAT on the replies like it does when connections flow THROUGH it.
Good luck!
