Redirect streaming traffic to specific WAN in dual WAN configuration
I’m new to Mikrotik and routerOs plateform.
I’ll trying my best to describe my context and problem.
Context:
L009UiGs @ router OS V7.12.1
ETH1: WAN1(named ADSL)@192.168.10.5
ETH2: WAN2(named LTE)@192.168.8.1
ETHx: LAN@192.168.88.0/24
Currently, and according to youtube/forum help, I was able to create a failover configuration WAN1->WAN2.
What i’m trying to do is to redirect streaming traffic such as Youtube and Netflix to WAN2 which has more bandwith.
I try to follow @Anav advise, especially on MANGLE rule with TLS request.
I’m missing something because, I see trafic on rules when going on Youtube, but no video is buffered and no trafic occurs on WAN2.
I appreciate some help.
# 2024-04-27 16:13:50 by RouterOS 7.12.1
# software id = **ELIDED**
# model = L009UiGS-2HaxD
# serial number = **ELIDED**
/routing table
add disabled=no fib name=ISP1
add disabled=no fib name=ISP2
add comment=defconf disabled=no interface=bridge_lan list=LAN
add comment=defconf disabled=no interface=ADSL list=WAN
add comment=defconf disabled=no interface=LTE list=WAN
add disabled=no interface=wifi1 list=LAN
set address-list-extra-time=0s allow-remote-requests=yes cache-max-ttl=1w \
    cache-size=2048KiB doh-max-concurrent-queries=50 \
    doh-max-server-connections=5 doh-timeout=5s max-concurrent-queries=100 \
    max-concurrent-tcp-sessions=20 max-udp-packet-size=4096 \
    query-server-timeout=2s query-total-timeout=10s servers=\
    8.8.8.8,8.8.4.4,**ELIDED** use-doh-server="" \
    verify-doh-cert=no
    /ip firewall address-list
add address=192.168.8.1 disabled=no dynamic=no list=LTE
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip firewall mangle
add action=accept chain=prerouting !connection-bytes !connection-limit \
    !connection-mark !connection-nat-state !connection-rate !connection-state \
    !connection-type !content disabled=yes !dscp !dst-address \
    !dst-address-list !dst-address-type !dst-limit !dst-port !fragment \
    !hotspot !icmp-options !in-bridge-port !in-bridge-port-list !in-interface \
    !in-interface-list !ingress-priority !ipsec-policy !ipv4-options \
    !layer7-protocol !limit log=no log-prefix="" !nth !out-bridge-port \
    !out-bridge-port-list !out-interface !out-interface-list !packet-mark \
    !packet-size !per-connection-classifier !port !priority !protocol !psd \
    !random !routing-mark !src-address !src-address-list !src-address-type \
    !src-mac-address !src-port !tcp-flags !tcp-mss !time !tls-host !ttl
add action=jump chain=prerouting !connection-bytes !connection-limit \
    connection-mark=no-mark !connection-nat-state !connection-rate \
    !connection-state !connection-type !content disabled=no !dscp \
    !dst-address !dst-address-list !dst-address-type !dst-limit dst-port=443 \
     !fragment !hotspot !icmp-options !in-bridge-port !in-bridge-port-list \
    !in-interface in-interface-list=LAN !ingress-priority !ipsec-policy \
    !ipv4-options jump-target=DnsToMove !layer7-protocol !limit log=no \
    log-prefix="" !nth !out-bridge-port !out-bridge-port-list !out-interface \
    !out-interface-list !packet-mark !packet-size !per-connection-classifier \
    !port !priority protocol=tcp !psd !random !routing-mark !src-address \
    !src-address-list !src-address-type !src-mac-address !src-port !tcp-flags \
    !tcp-mss !time tls-host=*.googlevideo.com !ttl
    !tcp-mss !time tls-host=*.netflix.com !ttl
add action=add-dst-to-address-list address-list=Streaming_users \
    address-list-timeout=12h chain=DnsToMove
add action=mark-connection chain=DnsToMove !connection-bytes \
    !connection-limit connection-mark=no-mark !connection-nat-state \
    !connection-rate !connection-state !connection-type !content disabled=yes \
    !dscp !dst-address dst-address-list=Streaming_users !dst-address-type \
    !dst-limit !dst-port !fragment !hotspot !icmp-options !in-bridge-port \
    !in-bridge-port-list !in-interface in-interface-list=LAN \
    !ingress-priority !ipsec-policy !ipv4-options !layer7-protocol !limit \
    log=no log-prefix="" new-connection-mark=markStreamers !nth \
    !out-bridge-port !out-bridge-port-list !out-interface !out-interface-list \
    !packet-mark !packet-size passthrough=yes !per-connection-classifier \
    !port !priority !protocol !psd !random !routing-mark !src-address \
add action=mark-routing chain=DnsToMove !connection-bytes !connection-limit \
    connection-mark=markStreamers !connection-nat-state !connection-rate \
    !connection-state !connection-type !content disabled=yes !dscp \
    !dst-address !dst-address-list !dst-address-type !dst-limit !dst-port \
    !in-interface !in-interface-list !ingress-priority !ipsec-policy \
    !ipv4-options !layer7-protocol !limit log=no log-prefix="" \
    new-routing-mark=ISP2 !nth !out-bridge-port !out-bridge-port-list \
    !out-interface !out-interface-list !packet-mark !packet-size passthrough=\
    no !per-connection-classifier !port !priority !protocol !psd !random \
    ipsec-policy=out,none out-interface-list=WAN !to-addresses !to-ports
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    192.168.10.5 pref-src="" routing-table=ISP1 suppress-hw-offload=no
    192.168.8.1 routing-table=ISP2 scope=30 suppress-hw-offload=no \
    target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.10.5 \
    pref-src="" routing-table=main suppress-hw-offload=no
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=192.168.8.1 \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
Sorry you cannot effectively trap websites for streaming traffic.
What you can do is dedicate a subnet for streaming traffic or an SSID if doing it over wifi.
Then you can mangle that subnet or associated vlan to a specific WAN.
Thank you a lot for your answer.
I’m not sure I’m understand your answer.
I’m trying to redirect Youtube trafic from LAN to WAN2. You advise me to:
  1. Create a new subnet (Eg. 192.168.20.0/24) instead of using 192.168.88.1/24 (current LAN shared for WIFI & physical ETH)
  2. Use MANGLE routine you have explained on another website to catch, mark, and re-routing youtube to this new subnet (which I already followed in my config)
  3. Create IP ROUTE to route this new subnet over WAN2 ?
That is correct ?
What I don’t understand is why do I need a specific subnet to redirect to WAN2 ? WAN2 is comming from another router. Is it possible to just redirect marked packed with mangle to WAN2 (through ISP2 table in my case).
Thanks again for your time.
PS: sorry for the bad gramar, i’m not english native language.
Not a problem due to encryption and type of protocols used by modern sites, it is IMPOSSIBLE to do what you are asking. Cannot be done on APP basis.
Thus for practical purpose I recommend have dedidcated subnets for such purposes.
So you can have vlan10 wired for normal WAN traffic (WAN1) and vlan20 wired for stream traffic (WAN2).
The challenge here is that every PC would need a small managed switch to that users can plug into which wired subnet they chose to use.
Similarly you could have on your wifi
vlan10 associated with WLAN1 and SSID - NORMAL
vlan20 associated with WLAN2 and SSID - STREAM
And thus users can select the wifi network by SSID, depending upon what they are doing.
OHHHH ! :slight_smile:
It’s more clear now.
So your old post about JUMP,MARK,ROUTE youtube tls trafic is not working anymore.
What a pitty there isn’t an “automatic” solution.
Thank you again.
→ No solution, I close the post
In theory, this should be somewhat possible with the current built-in RouterOS features. And of course, it depends on the apps (Web Browsers, VLC, etc…). RouterOS has a built-in SOCKS 4/5 proxy server which supports VRF. So, we can configure the SOCKS server to use WAN2 for default route (with the VRF selection). On the devices we can setup the apps that support SOCKS proxy (Browsers and VLC do) to use the proxy while the rest uses the normal network and WAN1. Or maybe let Firefox uses the proxy and Edge use the direct connection, for example.
