Redirect to, default setting
Hello we are using the MikroTik Router with the OS version 3.26.
Can somebody advise us how we can setup our boards with a default value for the Redirect to field?
Regards
what do you mean?
you probably want to preconfigure a number of devices with a specific configuration value?
you need to use the import ability of routerboards.
first type for example “/ip firewall filter export file=name”, then download the file “name.rsc” to your PC, open it with a text editor to check if all is there, then upload to any number of routers, and run “/import name.rsc”
