redirect..
dear sir,
i have MT 2.9.27 and it’s licenced and i don want to upgrade to V3 because i don wanna loose my 100 gb cache files. but i need to redirect some website like www.xy.com to www.zw.com in V3 it’s so easy with redirect option but how to do it in v 2.9.27. best regards
no way. upgrade to v2.9.51 - according to documentation, /ip proxy access has ‘redirect-to’ parameter in v2.9.51
i will loose my cache if i upgrade to 2.9.51?
best regards
is your old 100 Gb cache useful?..
yes mate cache always usefull even in small way becaus i pay per GB.
I meant: is it useful if it’s very old?..
yes bro it’s useful and it’s old.
just interesting: how did you checked it?..
just i am monitoring my local and public interface and 80% of time my local load more data than my public (that’s mean the cache reduce my bandwidth usage) so the cache is useful.
best regards.
I’m sure the same picture will be after some hours (minutes?) when starting with clean cache =)
