redirect
Greetings guys,
Does MT send icmp redirects when it should, Ive tested and it doesnt so i need a confirmation.
How are the netfilter tweaks which you modify in /proc confed in MT and does MT support the feature where you can check for async paths and drop. If you aren`t going to send the packet through the interface you received it than drop it.
I’d say that’s the wrong place to ask - as it’s a user-to-user forum, not an official support forum from MikroTik.
You should better ask support@mikrotik.com
The answer would be an appropriate posting content over here, though :wink:
Christian
I just didnt classify this question as such. Anyway theres still no answer.
Anybody tried to config even if it isn`t supported by default or at least looks like still no answer from MT for 'Unicast Reverse Path Forwarding ’ and redirect thing.
I`ve glanced through RFC1812 and it says that every router should have support for this.
