Redirecting connections count into variable/file
Hi!
I have a question, I’m writing a script to get some mearurement data from the router. One of the should be the connections count, printed with
/ip firewall connection print count-only.
Now, does somebody have an idea how to redirect this print-out into a file or set it as a variable, I’ve tried everything from :log, to /ip firewall connection print file=xxxx count-only, and nothing worked.
Please help.
Best regards
Michal Podoski
[admin@main_gw] > :global aa [/ip route print count-only]
6
[admin@main_gw] > :environment print
Global Variables
aa=6
Local Variables
Global Variables
aa=6
Local Variables
[admin@main_gw] >
Hope this helps.
Eugene
[@mikroHome] > :global connectioncount [/ip firewall connection print count-only]
461
[@mikroHome] > :env print
Global Variables
connectioncount=461
Thanks.
That’s the thing I need.
Best regards
Michal Podoski
