Redirecting outgoing connection to an internal server
I have been using two bridges: one for wired connections and one for my wireless network. I read somewhere that this is bad as only the first bride can be hardware offloaded.
As part of this configuration I used a dst-nat rule to redirect traffic from my LAN to my public IP address to an internal server IP address, similar to a hairpin NAT.
Tonight I merged the two bridges and the dst-nat rule stopped working. My incoming port forwarding rules continue to work without issue. After spending several hours troubleshooting I setup local DNS and called it a night. Does anyone know why merging the bridges broke the redirect?
This is almost identical to the problem described here: http://forum.mikrotik.com/t/redirect-dst-nat-a-non-local-public-ip-port-to-internal-server/141859/1
hi,
what do you mean by merging 2 bridges? how?
probably your mitm redirect should be easy enough as long as your target server is on separate interface than those wired and wireless lan. let us say a dmz interface for the server?
dst-nat should be enough. or you can give us some simple drawing about your network?
/export file=anynameyouwish ( minus router serial number, any public WANIP information, keys)
@wiseroute I “merged” the bridges by taking all of the ports that were on bridge 2 and adding them to bridge 1. Bridge 2 consisted of wireless access points which had their own subnet, DHCP server, etc…
What do you mean by “on a separate interface”? Should I remove the ports I use for my homelab servers from the bridge? That would negate the performance benefits I sought by only having 1 bridge in the first place.
My network is super simple. I have a MikroTik RB4011iGS+5HacQ2HnD-IN. My fiber internet is plugged into port 1. All other ports are bridged. Two ports are used for some homelab servers running docker containers, e.g. pi-hole, and two ports are used for dedicated wireless APs. I do have some fancy firewall rules to prevent port scans but they shouldn’t affect a dsn-nat rule.
What I’m trying to accomplish is to be able to connect to mydomain.com hosted on my homelab without having to rely on pi-hole for custom DNS. This causes some annoying issues that the dst-nat rule would fix if I can get it working, e.g. when switching from WiFi to mobile on my phone I have to disable/re-enable my WireGuard VPN to force the DNS to refresh. If it always uses the public IP it wouldn’t be an issue.
@anav I’d rather not posy my config if possible. It’s huge with many comments, e.g. devices labeled with family names, etc…
Apologies for double posting. I should have read the freak’n manual.
Hairpin NAT gave me the background I was looking for. Very insightful. Then I followed the advice from Hairpin NAT - The Easy Way for my config. Hopefully this helps someone else in the future.
Can anyone explain why it worked without the hairpin rule when I had 2 bridges? Maybe it had nothing to do with the bridges at all and more to do with being on a different subnet?
This. If internal server and internal client are not in same IP subnet, then hair-pin NAT is not necessary. Because they have to “talk” via your router anyway and firewall is able to un-do NAT without “pulling” return traffic by applying the SRC-NAT rule (which makes hair-pin NAT operational).
