Redirecting Ports for Well known services
I have a situation where I would like to allow a customer to access telnet on his computer which is inside of my NATTED network. Because I still want to use regular telnet to access the router, I wanted to set up a situation where the user can telnet to a specific port (say 13005 for example) and have the MT redirect it to his specific computer using the proper port for telnet (23)
I have this rule in place, but it does not seem to be working correctly
chain=dstnat dst-address=MT_WAN_IP dst-port=13005 action=redirect to-addresses=CUST_LAN_IP dst-port=23
I have also used action=dstnat without any better results.
I hope that someone can tell me what I am missing here. Thanks
I would suggest this:
chain=dstnat dst-address=MT_WAN_IP protocol=tcp dst-port=13005 action=dst-nat to-addresses=ROUTER_INTERNAL_IP to-ports=23
I use this rule all the time for RDP etc, with no problems.
Remember to put this rule above your Masquerading rule, otherwise it might not work.
