Redistribute Routes
Routers :
As the subject, i want to distribute any BGP routes from R1 which is taken from ISP router to R2. I have no idea how to setup the configuration coz usually i only take routes from ISP router, but never try to distribute it to other routers. Maybe someone in this forum can help me.
Thanks.
If you are getting your routes via BGP, use BGP between your 2 routers and on the instance you use, tick ‘Redistribute other BGP’, should learn all the routes.
I’ve already tick Redistribute other BGP on R1, but R2 still not learning the routes from R1 :frowning:
Are R1 & R2 established as BGP neighbours? Perhaps upload your BGP configs…
