Redistribution routes PPPoE Client subnet / framed IP.. help
Helo to all!
I have a net as you can see below: a lot of node connected by radio link, in pure routing (static routes).
Some node (not all) are PPPoE Server and assign by RADIUS to PPPoE client a private IP Address from local subnet (CDIR /24).
Eahc radio link is on separated interfaces and separated from distribution interface.
I need to:
  • redistribute dinamically routes for each PPPoE local private subnet (for redundance first)
  • redistribute dinamically routes for framed (single) public IP assigned to PPPoE Client from centralized pool
Can you help me to individuate proper routing protocol to implement this?
tnx
I have a similar network and wanna implement the same thing. OSPF is the proper protocol I guess.
Good. Can you help me? Can you describe me the guide-line?
in a routed network, you cant have a single centralized IP pool unless you use a RADIUS.
OSPF is neccesary for dynamically updating the routes (addresses) assigned by RADIUS to the clients.
I will try to work for it when I have time. Please update if you find valuable info.
RADIUS is for manage customer profiles.
Hi guys,
no more? :slight_smile:
