I happened across this page https://bryanward.net/wp/2023/02/08/apples-to-apples/ and presentations on Youtube.
- Apples to Apples: An Analysis of the Effects of mDNS Traffic: https://www.youtube.com/watch?v=miRV8qDOKBE
- How mDNS Can Kill Wi-Fi Performance And What To Do About It: https://www.youtube.com/watch?v=rd0dEwu4UJ4
It got me thinking about reducing airtime for broadcast traffic on Mikrotik, especially on larger networks bigger than a household with 100+ devices without the need to be draconian and disable any client to client comms and blocking most or all multicasts and broadcasts.
I don’t have any real way to measure the actual time spent by the radio on handling broadcast transmissions so this is a bit of a thought experiment. Based on the talks I am testing the following on a Wifi/qcom-ac only network with cAPac’s. Multicast enhance is enabled. These settings are running on each cAPac with 2 VLANs and SSIDs.
Dropping all IPv6 mDNS. May or may not have consequences but it seems like redundant traffic for the most part.
Sanitising the TTL and DSCP on IPv4 mDNS traffic.
The usual priority mangle to make sure WMM works properly.
As the bridge on qcom-ac is using VLAN filtering I have turned on IGMP snooping as well.
The AX devices don’t use VLAN-Filtering for their CAPSMAN client interfaces normally (to date) so I haven’t tested them.
Comments and suggestions welcome. I imagine there are a lot of other things that can be dropped too. The filtering should probably become more of a whitelist than a blacklist.
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-vlan=yes
/interface bridge filter
add action=drop chain=forward comment="Drop all IPv6 mDNS" dst-mac-address=\
33:33:00:00:00:FB/FF:FF:FF:FF:FF:FF mac-protocol=ipv6
/ip firewall mangle
add action=change-ttl chain=forward comment="Sanitise mDNS TTL to 1" \
dst-address=224.0.0.251 dst-port=5353 log-prefix=ttl new-ttl=set:1 \
passthrough=yes protocol=udp src-port=5353 ttl=not-equal:1
add action=change-dscp chain=forward comment="Sanitise mDNS DSCP to 0" dscp=!0 \
dst-address=224.0.0.251 dst-port=5353 log-prefix=ttl new-dscp=0 \
/ip firewall mangle
add action=set-priority chain=postrouting comment="Set Prio outbound on Wifi" \
new-priority=from-dscp-high-3-bits out-bridge-port=all-wireless \
passthrough=yes
