At my home, I have two RB962UiGS-5HacT2HnT – hAP ac device running routeros7. I am using them as wireless access points mainly. One of them is running dhcp, radius and usermanager for the whole home network. I use this machine to assign ip addresses based on mac address. Of and on, I have some other problems and my machines could not access the raidus server/usermanager/dhcp in my the configured machine.
How can I make make these services redundant as the way they configured in the second machine. I would like to setup the second machine the same way but it should be the backup machine. Is it possible?
Any insight, help much appreciated.
hello,
yes, you can make those 2 routers in redundant setup - but not for the:
ip/gateway/routing part. they should have additional vrrp like and pbr/nat mechanism to handle/take over user sessions.
radius capmans part. you will need another device to handle those 2 routers user sessions.
actually those 2 routers are having identical settings (except things mentioned above) - so for the backup part could be considered easy routine.
hope this helps.
