I understand that it may be considered inappropriate to search this forum for a replacement for mikrotik products.
I think it is easier for those who know the device (hap AC3) to recommend a replacement with poe OUT that better fulfills the Wi-Fi functions of a Home.
Our ISP gives us internet through Mikrotik Cube60 AC 300/100Mbs.
hAP AC3 is not capable of moving this speed in noisy environments.
Any recommendation?
Thanks a lot
I have mikrotik as main router and Asus RT-AX56U as AP. It has WiFi 6, is very powerfull and has roaming 802.11r. Once set up, you can forget about AP very solid.
Oh but I respectfully disagree there.
I can easily push close to 500Mb (sometimes more) using hAP AC3 using 5Ghz on my internal network.
So 300/100 shouldn’t be a problem either (I only have 200/20 at home to the outside world).
I do agree it required some careful monitoring from my side which channels to use but it’s not rocket science either.
Especially wifiwave2 should help a lot.
Sure you can but that does not take away the fact hAP AC3 is more then capable to handle 300/100 which OP claims to be a problem right now.
It is not the device. It’s the config which most likely is the problem.
If he used the standard drivers or caps-man… 300 is a gift.
Also even with the Wave 2 driver… It’s best client serving wifi I have ever seen from Mikrotik. But it’s about equal to other ACv2 wifi devices from 2016.
